I am fully aware of all the nasty things that can happen with *too* much oil, e.g. blown seals, PCV contamination, high oil consumption, frothing and general engine apocolypse
However, I've been somewhat convinced that having more oil is better (longer oil life, mostly, due to dilution of the polution
That said, I have no idea how much you can overfill a Subaru Impreza TS (non-turbo) before problems occur... since it is a boxer engine, the crankcase is on the same level as the piston centerlines, so you could really flood the engine with oil if you're not careful.
Anyone here have any specific Subaru experience on how much you can safely overfill? Or if I'm way off base with my piston/crankcase being on the same level?
Yes, I'm aware that you *could* just keep adding oil and checking for bubbles, but how reliable would that be anyway?
Thanks in advance for any advice!
