Glad you asked, Critic, as I had forgotten to bookmark it.
Cut and paste from an EricL post on Acurazine:
I just looked at the Helms (2001 CL/CLS) and the bleed page is virtually identical to the Honda page you've shown. In fact the bleed sequence is identical.
The only item that isn't mentioned -- and I don't if you really care one way or another -- is in regards to the CLs with VSA, etc that have a small resevoir for the VSA.
On page 19-177 of the 2001 CL/CLS factory service manual:
VSA Fluid Replacement
1. Clean the area around the modulator unit.
2. Remove the reservoir cap (A), diaphragm plate (B), filter (C), and diaphragm (D).
3. Clean the filter.
4. Remove the brake fluid from the VSA reservoir.
Note: Do not spill brake fluid (yada-yada-yada) ....
5. Install the filter.
6. Fill the VSA reservoir with brake fluid until it reaches the upper line of the filter.
7. Install the diaphragm, diaphragm plate, and reservoir cap, then hand-tighten the bolts.
8. Operate the pump motor by driving the vehicle at 6 mph (10 km/h) or more.
9. Repeat steps 1 through 8.
10. Test-drive the vehicle at 18 mph (30 km/h) or more for a few seconds, and check that the ABS indicator and VSA system indicator do not come on.
11. Tighten the VSA reservoir cap bolts to the specified torque.
