The change the oil too often seems to have come from the Ford/Conoco study (mentioned heaps, got it's own thread once) which concluded that used oil provided greater wear protection than new...
Not an actual engine test, the test took used oil and did an (IIRC) pin on disk to measure wear (did have some radiological trace element testing to verify)...versus new oil.
Has been interpreted as more wear after an oil change, tribofilms are gone after an oil change, and stupidly (IMO), that the in service lubricants thinned down enough to protect better (in a pin/disk, after the paper clearly showed thickening).
Test did indicate that the additives are activiated by use, becoming more effecive (more varied species ???) but didn't say that the tribofilms were removed each oil change.
Has me (hack chemist) adding a little MoS2 with each oil change...Formerly used SxUp.
