Checking out the Fuchs Silkolene line of MC oils, but it looks like a wide range of oils are actually distributed here too, even the 0w-20!
Electrosyntec Oil Technology – The Ultimate Protection For Your Engine
Everyone knows that Silkolene produces the genuine article - scientifically researched, chemically advanced engine oils. The technical advances that have enabled Silkolene to introduce Electrosyntec are derived from aerospace technology and subsequent sound scientific research and thorough testing under ultra extreme conditions with our racing partners.
Let's try and make understanding Electrosyntec and its electrostatic adhesion properties easy. Everyone talks about atoms but we only see or feel electrons. Electrons are responsible for colour, taste, texture, hardness…. you name it. Equally so, our mechanisms of perception depend upon electrons; we feel, taste and see with them! OK, the nuclei of atoms are responsible for weight, but each nucleus is deep down beneath clouds of electrons, and not approachable by any normal means.
Metal atoms have loosely-held outer electrons which are free to move about, even though the metal nuclei and their more tightly-held electrons are fixed in a more or less rigid framework (like a crystal lattice,). The 'free electrons' hurtle about in the open spaces between atoms, especially when under the influence of an electric current. However, they are still attracted by the positively-charged nuclei, so they cannot (at normal temperatures) escape from the surface of the metal. In fact, they spend more time just below the surface, which means there is an overall positive charge, which has not been fully neutralised by electrons in this region.
When a metal is immersed in a liquid, the positive surface can attract the molecules of that liquid if it has regions of negative charge, The sorts of molecules which are likely to have such regions are non-symmetrical types with atoms that 'pull' more electrons to one end, giving it a negative charge. Obviously, this will leave the electrons a bit thin at the other end, giving that a positive charge.
Electrosyntec molecules behave in this way. When a layer of Electrosyntec molecules is in place, another layer will be attracted to the outer positively charged ends of the first layer of molecules and then another to the exposed negatively charged ends of the second layer and so on, This is electrostatic adhesion and it has been shown that these layers do exist, and that anything from 10 to 50 layers can build up on a metal surface. This is enough to be significant where lubrication is concerned; on finely-finished machined surfaces, the layer can be of similar depth to the surface roughness: i.e. 0.1 to 1 micron (I micron = one thousandth of a millimetre).
OK, so now we understand how electrostatic adhesion provides this layer of lubricant in Electrosyntec products… but what benefits does it provide? The chemical bond formed with the engine surfaces forms a tough film which stays in place while the engine is shut down, reducing wear during the vital few seconds at start-up - this means that your engine and transmission are protected against wear at all times, These layers of Electrosyntec molecules also permit the use of less viscous lubricants, which reduce drag and therefore release additional power from your engine.
http://www.710oil.co.uk/pdf/ProR0w20.pdf
The Synthetic Myth
What do we mean by the word 'synthetic'? Once, it meant the 'brick by brick' chemical building of a designer oil, but the waters have been muddied by a court case that took place in the USA a few years ago, where the right to call heavily-modified mineral oil 'synthetic', was won. This was the answer to the ad-man's dream; the chance to use that sexy word 'synthetic' on the can… without spending much extra on the contents! Most lower-cost 'synthetic ' or 'semi-synthetic' oils use these 'hydro-cracked' mineral oils. They do have some advantages, particularly in commercial diesel lubricants, but their value in performance engines is marginal.
True synthetics are expensive (about 6 times more than top quality mineral types). Looked at non-basically, there are three broad categories, each containing dozens of types and viscosity grades:-
1) PIB's (Polyisobutanes)
These are occasionally used as thickeners in motor oils and gear oils, but their main application is to suppress smoke in 2-strokes.
The two important ones are:-
2) Esters
All jet engines are lubricated with synthetic esters, and have been for 50 years, but these expensive fluids only started to appear in petrol engine oils about 20 years ago. Thanks to their aviation origins, the types suitable for lubricants (esters also appear in perfumes; they are different!) work well from -50º C to 200º C, and they have a useful extra trick. Due to their structure, ester molecules are 'polar'; they stick to metal surfaces using electrostatic forces. This means that a protective layer is there at all times, even during that crucial start-up period. This helps to protect cams, gears, piston rings and valve train components, where lubrication is 'boundary' rather than 'hydrodynamic', i.e. a very thin non pressure-fed film has to hold the surfaces apart. Even crank bearings benefit at starts, stops, or when extreme shock loads upset the hydrodynamic film. (Are you listening, all you rally drivers and off-road fanatics?)
3) Synthetic Hydrocarbons or PAO's (Poly Alpha Olefins)
These are, in effect, very precisely made equivalents to the most desirable mineral oil molecules. As with esters, they work very well at low temperatures, and equally well when the heat is on, if protected by anti-oxidants. The difference is, they are inert, and not polar. In fact, on their own they are hopeless 'boundary' lubricants, with less load carrying ability than mineral oil. They depend entirely on the correct chemical enhancements.
In fact PAOs work best in combination with esters. The esters assist load carrying, reduce friction, and cut down seal drag and wear, whilst the PAOs act as solvents for the multigrade polymers and a large assortment of special compounds that act as dispersants, detergents, anti-wear and anti-oxidant agents, and foam suppressants. Both are very good at resisting high-temperature evaporation, and the esters in particular will never carbonise in turbo bearings even when provoked by anti-lag systems.
Castorene R40 Racing Oil
Castorene R40 racing oil is a Castor Oil based blend incorporating synthetic lubricants and additives which enhance the castor oils of naturally high film strength and resistance to seizure, this enhancement represents a significant advance in lubrication containing vegetable oil and minimises the risk of thickening or lacquer formation.
• Inhibitors derived from aircraft gas turbine engine technology give stability and oxidation resistance and both laboratory and racing tests have proved the product.
• Oil thickening and lacquer formation is reduced even in hot running engines such that the oil can be used for longer periods than those normally associated with castor-based products.
• Fully soluble in alcohol fuels and ideally suited for use in both air and liquid cooled racing engines running on methanol or methanol based fuels.
Note: These are not detergent grades, and more frequent oil changes are required than with additive treated mineral oils. Castorene R40 must not be mixed with mineral oils.
Silkolene Pro S 5W-40 - 100% Synthetic Oil For All Race Engines.
The ultimate 100% ester/pao synthetic high performance engine oil that provides optimum protection and extended engine life and reliability. It exceeds the performance requirements of virtually all engine manufacturers. Combines exceptional anti-wear performance and outstanding high temperature protection with excellent cold start characteristics. Suitable for both turbocharged and normally aspirated engines to ensure maximum economy and reduced emissions.
SAE 5W/40. API SL/CF CCMC G5 PD2, VW 500.00/505.00, MERCEDES 229.3, BMW, Porsche
http://www.710oil.co.uk/pdf/PRO%20S%20-%204%20Wheel.pdf
