I sent mine off two weeks ago and haven’t seen anything.
Not that long. Which Oil Analyzer lab did you send to? You can contact them.I sent mine off two weeks ago and haven’t seen anything.
They were pre paid shipping. The only thing I’ve realized is i put the paper inside the bag instead of the outside. Not sure how that affects things.Definitely send it by UPS for a faster turnaround time.
I wouldn't rush them. No pressure means the best odds for most accuracy in readings. If you rush the guy with the hangover, you may question the results in more than one place on that sheet of PDF paper.I've waited that long before. I'd call them up & tell them to put some speed on it. Make sure they have your email address.
How do you equate waiting over two weeks for UOA is "Rushing a guy with a hangover"? Does Oil analyzers/Horizon employ working drunks?I wouldn't rush them. No pressure means the best odds for most accuracy in readings. If you rush the guy with the hangover, you may question the results in more than one place on that sheet of PDF paper.
So let the poor lad recover from his bar-time headache. Maybe even suggest Motrin instead of Tylenol for best recovery time.
