Originally Posted By: Geonerd
Originally Posted By: d00df00d
Originally Posted By: azsynthetic
No one teaches oil leak in grade school so apparently you are just dreaming. Contaminants builds up over time, hahaha, now that is funny. Contaminants always build up over time no matter what, but you are getting rid of it at a 20-25% rate every 2K which is better than keeping it in there for the whole OCI duration.
Looks like the school system is in worse shape than I thought. Not your fault.
Here's how it works. The day you put the oil in, you have 4 fresh quarts. Let's say every 2,000 miles, 1/4 of the sump leaks out, and you add a quart.
At 2,000 miles, 3 qts are 2k miles old, and 1 qt is fresh (from top-off.)
Every 2,000 miles after that, you multiply each number by 0.75, and add one fresh quart.
So, at 4,000 miles, 2.25 qts are 4k miles old, 0.75 qt is 2k miles old, 1 qt is fresh.
At 6,000 miles: 1.69 qts are 6k miles old, 0.56 qt is 4k miles old, 0.75 qts is 2k miles old, 1 qt is fresh.
And so on.
See how that works? At all times, the majority of the oil in the engine is old. The oldest part gets smaller and smaller but it never goes away. This is why you eventually have to change the oil, even if it is leaking/burning and getting topped off. You could definitely run longer than if you weren't leaking and topping off, but you couldn't run forever.
Coping a snotty attitude isn't helping your case, mister.
After enough iterations, the system will eventually reach a stable balance, with the very 'old' oil making up a vanishingly small percent of the total. With good filtration and a constant influx of new oil to fortify the TBN, etc., the oil may never reach a point where it us unusable. There will certainly be no further 'build up of contaminants.' If the oil is serviceable at that point, something best determined by UOA, the OP would be fully justified in never changing the oil again.
Actually, for rigorous analysis using classical mathematics instead of an iterative numerical solution you need differential equations - and that's taught in the second year of engineering school.
The contaminate level would follow what is called a sigmoid curve and over time asymptotically approach a level lower than would be the case if no oil were being replaced - how much lower depending on the rate of replinishment.
