How Likely Is It That I Can Get Bank1/Sensor2 O2 Sensor Out?
Toronto, Canada
Got the P2A01 code in my 2006 Sierra 4.3l V6 once in February and it came back today. So I might have to replace the sensor. I have not done any troubleshooting yet.
On this salt belt 18 yr old truck, I was wondering how much of a fight I am going to have removing this sensor. I have the OTC oxygen sensor socket but don't have access to a hoist, so I will be working lying on my back. Doable or should I let a shop handle it?
If one sensor is defective, should I replace the other downstream sensor?
I have gotten them out, but I soak it, run it till it is hot and soak it again. Something like PB blaster. I have had sucess with that.
7/8" box wrench. Got three of those sensor socket, they all flex. Might be good for installing.
soak in PB blaster a day before you want to mess with it. soak it again, drive it, let it cool. soak it and torch it. then soak it again. i have a 7/8’s O2 sensor crows foot that makes quick work of O2 sensors. ALWAYS use a very thin layer of high temp anti-seize on the threads when going back together.
Got the sensor out, came out easy peasy. Did not have to heat it.
I cut off half the sensor with my angle grinder and then used a 22mm socket. Did not have to apply excessive force. Used my O2 sensor socket for installation.
I was expecting to have a fight on my hands, considering this was a daily driven 18 year old truck in the salt belt.
I was also expecting that the MIL would need a couple of drive cycles before it turned off but it turned off within a few minutes of driving the truck after the sensor replacement.
I love it, nice work!!
