I have two B&S flathead engines, one 6ish HP on a push mower(splash lube), the other 19ish HP on a JD rider(pressure lube). I commonly use new leftover oil from auto and ATV oil changes in my OPE. I have enough oil to change the mowers and refill it with low-SAPS oil that is left over from my TDI diesels. The low-SAPS oil isn't real "healthy" in zinc, or any other additive really. Though not ideal, would the oil hold up reasonably well for my engines that see max 50 hour OCIs?
