How important is it to match-up bypass relief valve psi spec to OEM oil filter?
Originally Posted by ragtoplvr
In fact oil pumps can be damaged by too high a pressure. They can wear the drive gears. They can split covers.
Rod
I would think any good Engineer whould ensure the oil pump was designed to be able to run a very long time in pressure relief without damage.
Originally Posted by berlyn
Correct. The problem is created if the valve opens at a higher pressure than indicated or at all.
In that case it's a faulty pressure relief valve, therefore an abnormal operating condition, so anything could go wrong in that case.
