Originally Posted By: XS650
Originally Posted By: crinkles
how does cellphone radiation vary from say 801.?? n/b/g wi-fi networks?
I'm not concerned about cell phone rf radiation, but since you asked what the differences are...
Routers have lower transmit power and normal people don't spend hours with their router held against their head.
RF strength is inversely proportional to the square of the distance, so even a few inches as opposed to being in contact with the device makes a BIG difference.
From what I remember cell phone RF power is capped at 2W, and if you have good signal where you are it can be as low as 0.5W. Usually router has 100mW (0.1w) or less output power.
Either way, the EM wave is usually not cancer causing and the most it can do (in physics, not statistic collected by radio phobics) is that it may warm you up. The 2.4GHz from wifi and blue tooth is what your microwave oven uses to heat your food, but they are in the 1000w range rather than 0.1w range, so imagine how much heat it takes to cook your brain and how much your cell phone in the worst case frequency can cook your brain.
Not much, you get more brain damage from sun bathing than this.
