Took this today, after an hour of mowing the lawn with the tractor. Grass wasn't particularly super high, but it was high enough. Engine RPM at max is 3100RPM, Briggs 21HP OHV single cylinder.
Thought this seemed a bit hot... Then again, I don't want to know how hot the pressure washer was running, after 40 minutes of full load in the same temps. Temps were around 93 degrees, for the record. Both engines running Rotella T6 5W-40
