I've been running 5w20 Pennzoil Platinum or Mobil 1 while towing with our 2004 (newer style) f-150 5.4 3 valve. Towing about 6500lb travel trailer. Oil temps scare me though. Going up grades, maybe 5 minutes running at 3800-4200rpm, 45-50mph it has gotten as high at 248F. I have stopped and let it cool when this happens. These were 70-75 degree days.
Normal "easy" running with the trailer, oil is about 220. Daily driving is 200. Engine coolant temp stays 195 regardless of use or oil temp. Trans stays very happy 155-165 all the time as well. I use the EDGE programmer on tow mode and for the temp gauges. Truck has towing package - essentially gearing, bigger rad, bigger trans cooler, bigger alternator. 60k miles on truck. No engine oil cooler though.
I don't like it as we'll end up doing some mountain runs sometime. I'm considering a sandwich adapter and external oil cooler with thermostat controlled fan.
Should I be concerned with the oil getting this hot???
Thanks
Thanks
