How do you choose an oil filter?
Houston, TX
I have a Generac generator with a Mitsubishi 4G64 engine
The stock filter, 0A45310244, is very expensive. Someone suggested FRAM Ultra XG7317, but now I'm going down the rabbit hole of oil filter cross references and there are so many options
For example,
Baldwin B179 at $6.82 - https://www.rockauto.com/en/moreinfo.php?pk=6365154&cc=0&pt=5340&jsn=183
Or this Hastings BALDWIN LF240 at $4.76 - https://www.rockauto.com/en/moreinf...y7njTaF6M0cGZIJLCkITNKWOmz4OAnygw7MF4B1mzNw==
Or this Larger WIX at $9 - https://www.rockauto.com/en/moreinfo.php?pk=579532&cc=0&pt=5340&jsn=142
Assuming they all fit and work which I assume they do, what specs am I really looking for to determine which is "best" to stock up on?
Looks like you posted a similar question a couple of years ago.
Regarding filters, there is no real "best". Buy a cheaper filter that matches the cross-reference and don't look back.
Are things like the Bypass valve PSI a real concern? Thinking in general and not just for the Generac
For example on my Light Tower, the OE Kubota filter has 8-12 PSI Bypass, but the filter I'm running, the Baldwin B161-S has a 20PSI bypass
Perhaps I should be looking for a filter with lower bypass?
I just ordered a case of Pentius UXFL PLXC7317 for the Honda Pilot off Amazon for $5 each. Currently using Amsoil EA15K13, but started seeing reviews where there's potential leakage around how the bypass valve is attached to the filter element as well as the quality control being lower than one would expect from a premium-priced filter.
WCW has good things to say about the Pentius, and I found this guy on YouTube, Crazy Bill's Garage, who cut open a new one and was surprised and impressed by its quality, e.g. gasket and ADBV both silicone, bypass valve construction, number and even spacing of pleats, etc. Made in Korea.
I just follow the trends on this forum and go from there. 🤷‍♂️
You could very well see a case minus one for sale soon, depending on the latest "best" filter recommendations.
Life was so much simpler before all these new-fangled oils and filters were being made. I can only guess the number of marketing majors in college has grown exponentially.
Higher bypass is preferable, there's going to be less instances of unfiltered oil entering the oil galleries. Other then that I see no downsides, other than the bypass needs to open well below the maximum oil pressure set by the oil pump relief. As the filter gets more restrictive in use, the oil pressure will rise automatically (before the oil filter) as pressure is directly driven by restriction to flow.
From my understanding the 4G64 is a close cousin (Identity block) to the 4G63. If the oil filters are the same have you considered looking for filters for the 4G63. I think it was a much more common engine.
A filter with a higher bypass setting will cause a larger drop in oil pressure if the oil filter clogs, which increases the risk of rod bearing damage. If you don't neglect oil and filter changes, it shouldn't matter, but I still wouldn't go higher than 15 psi.
The Pentius XL 7317 is a great filter and has a 13 psi bypass valve. The Pentius PLB7317 is also good, but less efficient. 12-packs are $60 for the XL and $37 for the PLB on Amazon. The Baldwin or Hastings filters are also fine if you're not concerned about efficiency.
When the oil pump's relief valve is open, it won't be able to compensate much for the additional restriction. On a 3600 rpm generator, the oil pump PRV is probably cracked open at all times, so filter restriction will have a substantial effect on oil pressure.
oil pump reliefs are in the 70 psi range, oil filter bypass 20 psi. no engine "needs" 50 psi+ to feed oil to bearings, or evn for vtt which this engine won't have.
But a drop in oil pressure "after" the oil filter can definitely be used to judge filter loading.
For example,
Or this Hastings BALDWIN LF240 at $4.76 - https://www.rockauto.com/en/moreinfo.php?pk=6364992&cc=0&pt=5340&jsn=465&_nck=jb38c6P4Fi5lb3DXs3729yqYTVecIHNXf+H89gDLrWNFXeNSX9b8iPFQ31DGig5XJQ58sq/+lvWDj/E5QzmMxK6IhS1NNpT89Vg4CzKVQDZZ7YnheQBu+LspEikYnxp0ocL/0hx4uQLVW5Bs0U10GdY3oxNF0NN0R9KEhZ/SF+rNeFQVt4kkQu/vPoG7QLhued1uLFUBtfk1VvIL1seOHWhB1/pKXmUoWk0pm3Q9UexdNvKUimV1FZZuhi7xkFt1tg6KgjPXpwNy7njTaF6M0cGZIJLCkITNKWOmz4OAnygw7MF4B1mzNw==
I look for big and cheap. A fe3800 is a big 3/4-16 filter and it's $13 for around a 12mu rating.
It likely won't matter. You have to run Kubota flood lights for thousands of hours to kinda dirty the filter.
Any of those Baldwins or Hastings will be just fine. Made by the same company. Not the most stellar at filtration, but for your application is just fine. I run a Baldwin on my mower.
