Originally Posted By: SteveSRT8
Quote:
On my Ford ZX2 Duratec engine, it would read way high first thing in the morning. I believe the dipstick tube developed vacuum during cooldown and sucked up the oil. It was okay for the second read.
This same thing happens on my 6.1. The initial reading is crazy high, wipe the stick and try again, get a normal one.
Interesting that the dipstick tube itself seems to protrude into the standing oil. Never seen that on old-school engines.
But hows this for a funny one: Wife's 05 PT Cruiser 2.4 will always read nearly a half-quart LOW (even on a "second pull") if its checked after an overnight sit. Start the engine for a few minutes (no need to actually warm it up), wait 5-10 mins, and check again- normal. And you get the same normal reading if you check it a few minutes after a hot shut-down.
On the 2.4, the housing that contains the counter-rotating balance shafts is attached to the bottom of the main bearing caps, and sits partially submerged in oil. Overnight, the balance shaft housing fills with oil, lowering the crankcase level. There's a pump that evacuates oil from inside the housing when the engine runs (to reduce windage), so running it a few minutes pumps the oil back out into the sump and raises the reading to the normal level.
