Specifically around 2013 or so? From what I've read the 3.5L V6 2gr-fe is a very reliable engine but it's a real pain to work on for almost anything beyond maybe replacing a serpentine belt. How good/bad is access in an AWD Highlander?
On HL is bad, but Sienna with 2GR-FE takes the crown of most inaccessible.Specifically around 2013 or so? From what I've read the 3.5L V6 2gr-fe is a very reliable engine but it's a real pain to work on for almost anything beyond maybe replacing a serpentine belt. How good/bad is access in an AWD Highlander?
Yeah but everyone will tell you that the I4 is underpowered. And gets the same mpg.Yeah, almost impossible. Get the I4 instead
Yeah, this is why I like the 4-cylinder Sienna so much. That's what I'd get if I needed a modern minivan.
“or so” generally means 2-3 years on either side. I wasn’t aware when it changed generations. Really what it means in this particular case is any AWD Highlander that’s around $15k and around 100k miles.That "or so" in your post piqued my interest in that you may mean later which would be the next generation. Not implying that's what you meant, but looking for a little clarification.
It’s interesting that you mentioned the Venza even though my question was about the Highlander because a Venza is one of the vehicles on my list of possibilities for an AWD vehicle. Right now the list is RAV4, Venza, Highlander, RX350 and CX-5…or a super cheap Matrix/Vibe if I stumble across a good one.Just not sure how a Venza is better than a RAV4--RAV4 is more likely to come with basic steelies and a larger trunk, and maybe cheaper tires? but I'm not sure if an I4 Venza would be cheaper to buy?
Smack my head, right you are, I may have read into your thread more of what was on my mind than yours. Read what I wanted to read, not what was typed. Apologies!It’s interesting that you mentioned the Venza even though my question was about the Highlander
For the extra 10 mins it takes to remove and reinstall the cowl, it ain't worth the struggle.If you remove the wiper cowl you can replace the rear plugs with out removing the intake or TB. Ive done it.
I commend the German's for their ingenuity, but the VR6 is far from a peach to work on. Anything on the front (radiator) side of the engine is a complete pain to get to unless you take the time to put it into service position. I understand that this is par for the course for VAG vehicles (I've worked on more of them than I care to count), but having to reposition the ENTIRE core support to do some relatively basic maintenance is as ridiculous as it is unnecessary.When one opens the hood of VW Atlas VR6, it appreciates ingenuity of VW engineers when they said: how about V, but with one head?
This is evidence that most information posted on Reddit is garbage and should be ignored. The noisy cam phaser problem on Toyota's AR engines is potentially catastrophic and yet extremely cheap and easy to fix. I fixed mine with a 5 cent part from Temu and about an hour of my time. The balance shaft rattle is also easy to fix, but a bit more expensive. This took me about 90 minutes to fix and cost about $50 for a balance shaft damper repair kit from Ukraine.One poster on reddit said something about the 2.7L having noisy VVTI phaser (which can be ignored) and balance shaft issues (which shouldn't?).
Simple DIY stuff that regular people do is super easy on VR6. Changing spark plugs etc. That is what I was referring to.I commend the German's for their ingenuity, but the VR6 is far from a peach to work on. Anything on the front (radiator) side of the engine is a complete pain to get to unless you take the time to put it into service position. I understand that this is par for the course for VAG vehicles (I've worked on more of them than I care to count), but having to reposition the ENTIRE core support to do some relatively basic maintenance is as ridiculous as it is unnecessary.
There's three VAG engines I'd consider to be "easy to service": the old 2.0 SOHC, early 1.8T's that had (less) junk bolted to them, and any pre-emission TDI.
