If you get a small jewelers screwdriver and bend the tangs up to release the tension you could remove it. Then if you want to reuse it you bend the tangs back down so the tension is back on the plastic pin.these are on some plastic pins that hold climate control vacuum pods in place
If you can't see them it will be pretty challenging IMO, but can't hurt to try.The issue is these pods are way up in the dash and im attempting to remove the pods without removing the dashboard so most of this clip removal will be done by feel. I was just hoping for some bizzare tool i have never heard of that helps with removal.
