How can I remove starlock washers?
NY
Is there some type of tool or some type of method I'm not familiar with? These are the lock washers in talking about.
these are on some plastic pins that hold climate control vacuum pods in place
Yeah I removed some from a lawnmower using a small flatblade screwdriver. Was my first time doing it and surprisingly it wasn't that bad, was able to reuse them too, they weren't in a critical spot in my opinion that I'm worried about them being worn.
If you're worried about damaging them on removal by being too rough with them, ace, true value or any other hardware store should sell them.
The issue is these pods are way up in the dash and im attempting to remove the pods without removing the dashboard so most of this clip removal will be done by feel. I was just hoping for some bizzare tool i have never heard of that helps with removal.
If you can't see them it will be pretty challenging IMO, but can't hurt to try.
I ended up removing the dash. It seemed to be the easier option than trying to fight with disconnecting everything. Ill post some pics later
So because I removed the dash I actually don't have to mess with taking off the washers. I made a tool that allows me to disassemble the vacuum pods in place so I don't have to risk breaking the posts.
