Originally Posted By: chevyboy14
Is that with both the 318 and 360
Actually that is a 360 issue.
As to the truck. It was approx 94-97 that they had the infamous transmission issues in the Rams. Some say it was fixed by 97 while others say it was 98. It is a toss up between those 2 years. The bad rep they got for that short period of time still plagues them to this day even though the problem was resolved for 98 trucks. I actually had a 97 Ram 1500 and the transmission was fine but I didn't use it the way that lead to most of the failures( extended idling ).
Overall the 94-01 Rams( 2nd Gen )were very good trucks. However I have to tell you that as GREAT of a motor as the 318 was it just was too underpowered for the 2nd Gen Ram trucks. They were too heavy for it even in 2WD models IMO. The same power issues plague 3rd Gen( 02-07 )Ram 1500's with the 4.7L. The 3rd Gen's got even heavier and once again Chrysler dropped in a mechanically fine for the most part, but vastly underpowered, motor in a very heavy truck.
I had a 94 1500 2WD w/ the 318 and it could barely get out of it's own way. A friend had a later model w/ the 318( his was an extended cab - 99 or 00 as I recall )and it too was a DAWG! Their fuel economy isn't measured in MPG but rather MPF( miles per foot ). Just horrendous MPG from the 318 Rams. MIne got 9-10 MPG on it's best days and I drive very conservative( even when gas was $1 a gallon and I could have cared less about MPG ).
If the truck is cheap enough and it runs good, and you don't need it for towing and hauling major loads, AND you can afford to put gas in it 2-3 times a week( if you drive it a lot ), then go for it. Me personally I would never buy a 2nd Gen w/ a 318 again. I had two 2nd Gen's with the 360 and that is the appropriate motor power wise. HUGE difference. MPG wasn't much betetr but it was some. Maybe 11-12( and those were 4WD models as well ).
