- Joined
- Sep 26, 2010
- Messages
- 9,807
We recently moved from Houston to Colorado Springs and have been making improvements as expected when buying a used house. I spent the past weekend replacing all of the switches and receptacles in the house. It was built in 2002 and many of the receptacles would no longer firmly hold a plug and the switches were toggle type which I have hated “forever”. The originals were all Leviton and I replaced them with Eaton “Decora” style.
I have also never been a fan of the push in “quick connect” type of wiring and have always used the side screws for all of my connections. A number of the 3 Way switches had cracked/broken plastic where the wires were pushed in so I am glad that I elected to replace the switches along with the receptacles. Another thing that I noticed is the electricians used both quick connect and side screws on many of the receptacles with 6 or more wires connected to about 10 of the receptacles.
From my experience, this is a not correct and not to be done. When you have this situation, you should instead wire nut the bulk of the wires together with a single wire extended to the receptacle which is what I did for all instances that I encountered.
It has been more than a minute since I reviewed the electrical codes, but can any electricians tell me if something changed and the current trend is to use both side screws and quick connect to “bond” all of the wires as opposed to wire nutting them together? I am assuming this is a way for the electrician company to save time, but it seems both lame and lazy.
