I did the EXACT same thing this weekend, but I have a 240/50 amp plug in my garage. I got enough 10/2 wire from an electrical store to run from my gen. to the plug. Genset sits outside and I can actually shut the doors. Make DANG SURE your wire is rated for 30 amps, most typical romex wire will handle 20 amps easy, but double check for 30. One thing....make sure you SHUT THE MAIN OFF FIRST or you'll be either causing brownouts throughout the neighborhood or you'll kill a line man when they try to fix the problem. Make sure you know what your doing if your going 240/30 amp service like I did. You'll probably have four wires from the genset...ususally green/black/red and white. Typically, red and black will be hot with 120 volts each, with green/white being neutral or ground. When going to your circuit panel, make sure you match them up correctly. Take volt readings before hand to insure that. You don't want to be figuring that all out in an emergency. Most circuit panels will normally have only three connections....two hot and one ground. You can combine both ground/neutrals to one common ground if you have to.
