Originally Posted By: Trav
Originally Posted By: Kira
Yo Trav, What's Hylomar? I have a buddy who applies a THIN smear of silicone sealer on barbs.
I have no problem with wiping a sealer on any hose/pipe barb but I do want it to let the hose off.
Kira, this is best little known product for DIY there is as far as sealers go, I use a lot of it and keep a few tubes on hand. The only place its not best is as a thick filler on end gap gaskets, silicone is best suited for that but for almost everything else this is superior in every way. You want the M it is a medium viscosity and perfect for automotive uses.
Getting the hose of later is no problem whatsoever, just a little twist and it comes right off. It also acts as a short term lube when installing the hose. Once you use it you will never be without it. Now I only buy the smallest tube of silicone I can get then throw it out after use because it goes hard in the tube thats how little I use it anymore.
This is a decent price for USA.
http://www.ebay.com/itm/HYLOMAR-M-BLUE-UNIVERSAL-JOINTING-COMPOUND-/192106179636?hash=item2cba6bac34:g:9~cAAOSwFNZWyyIC
Some info.
http://hylomar.com/hylomar-product-range/gasket-jointing-compounds/
https://www.newmantools.com/chemicals/hylomar.htm
Trav, you are a living wikipedia with a plethora of infomration.
I learned something new today and I always struggle with removing those [censored] hoses!
Thank you for this Hylomar, bookmarked
