Honda snowblower - mfg's oil recommendation
Great Lakes
I found this in the owner's manual of a Honda HS520A single-stage snow blower with a 160cc engine (GC160):
Would there really be a problem running 0w30 oil in ambient temps of around 20F? I was thinking of just using GC in it...
Nope you would be good to go!
My Snowblower has a Tecumseh engine and it and it calls for a 5w30 and I have run AMSOIL Signature Series 0w30 and Amsoil 10w30 4 stroke formula and we get frigidly cold up here and it runs perfect.
Not sure... Maybe they are just trying to show you when it's absolutely needed, but then again why wouldn't they just spec 0w30 for all season? Too expensive??? I dunno.
Wouldn't worry about it though... The technology in these engines has changed very little and the old ones used to survive on much lower quality oils from back in the day and most people never changed it. So you changing it, using a high quality oil will be more than fine IMO.
Don't over think it!
You can obviously from the chart pick a few different viscosities depending on temps.
My dealer has seen a lot of ruined snowblowers from using an oil with too low ZDDP or viscosity.
I am running what he thinks is the best possible choice.
Motul 300 V 5W-40 1400 ZDDP Double ester....GRP V. synthetic.
$ 15.00/qt.
But the viscosity grades don't seem to overlap. Am I supposed to switch from 0w30 to 5w30 just because the outside temp rose from 0F to 20F? That's what I don't get.
That doesn't make sense because they are both a 30wt oil, just one flows better at colder temperatures... Who cares if it flows better at higher temperatures, I would think this would be a good thing ... No ?
That chart would overlap a heck of a lot more if it really took into consideration synthetic oil's flowability and heat resistance.
You would not use anything but a HDEO synthetic with lots of ZDDP anyways right?
Well, I'm hoping GC qualifies.
OW oils are all synthetic.
I've run synthetic 0w30 for several years now, GC first and Mobil 1 the last two years; does great.
Ran 5w30 before that, also synthetic.
18 year old simplicity w/ 8hp Techumseh.
Quattro Pete But the viscosity grades don't seem to overlap. Am I supposed to switch from 0w30 to 5w30 just because the outside temp rose from 0F to 20F? That's what I don't get. [/quote said:
Yeah, especially if the snowblower is garage kept. I would think the 0 weight would be for cold outside starting, and you wouldn't have that concern if it's ten below while you're blowing snow all over the place with a warmed engine.
