My 09 Civic with 65k has extremely dark PSF. I "flushed" it at 40k miles with OEM Honda Power Steering Fluid. Using the baster method repeatedly removing all fluid from reservoir and refilling then cranking the steering wheel back and forth ten times while the car was running and on jackstands until the fluid was clear.
It looks like $#!* now.
So, I am going to do the same technique with new PSF. What PSF would you use? Is there a Honda rated PSF that is of better quality than the OEM Honda Power Steering Fluid? I will use the best available Honda specced stuff I can find.
