Good day BITOG people,
Based in the UK.
So, I have a JDM k24a engine that is new to me (2nd hand) in a 90s civic track car. Upon inspection the internals of the engine were squeaky clean, no varnish, sludge build up etc in the bottom end, timing cover etc whilst I was doing the timing chain, oil pump etc.
What I did find was the previous Japanese owner had done quite a few miles on an open pcv valve, soaked intake manifold, intake valves and the crowns of the pistons were quite grubby.
I suspect oil control ring issues from carbon buildup and nasty top end partially burnt oil getting into them.
Oil consumption is currently at 400/500ML (1/2qt) every 1k miles ISH, extrapolating from my current 800miles use on the car. She made 260hp and runs a dream, gets used hard, doesn't smoke. PCV setup no longer recirculating into the intake, will be adding a vacuum assisted catch can setup purely for the bottom crank case in the future.
Current oil is 5w40 millers CFs nt+.
Fuel 99 shell vpower
I plan a thorough b12 soak and will use this post to update as I go. I'm on track the 26th May and will carry out the soak the commencing week.
Outside of the b12 soak, what UK available treatments would you also recommend...no DSMO as the sump is painted internally.
First picture is piston crown prior to 800 miles running on clean map using stated oil and vpower fuel, no pcv.
Second picture, 800 miles as above. Notice wet edge, third is worst offender, piston 3. Will be ordering a 90 degree mirror for bore scope to check cylinder scoring.
Many thanks
1
2
3
Based in the UK.
Many thanks
1
2
