Honda head Gasket? Stumped.
Hi, I have 30 yrs DIY wrenching experience and I'm stumped.
Bought a 2018 Civic EX 2.0 (no turbo) 140,000 kms from my wife's co-worker in mint condition and no past problems. Well, it's definitely loosing coolant. Here are my tests & results to date:
- no visible leaks
- no mixing of engine or trans oil
- compression 175/170/110/175. The 110psi cylinder is leaking out the intake valves (leak down test).
- 15psi rad test loses 1psi after 10 hours on cold engine. Loses 1psi after 1 hour with warm engine.
-Camera inspection of cylinders at bottom: great cross hatching, no blow by, and no coolant drops. Pistons are not damaged. All pistons have the same amount of carbon build up and color.
- spark plugs are original and have the same color. They look normal.
- on cold start-up the exhaust is clear for 5 secs and whitish-grey for 10 secs, then clear. I have an 02 civic and 15 Odyssey and they both have clear exhaust at start up and no whitish-grey.
Did I miss anything before I remove the head? Any recommendations on this particular Honda? It's K20C2 engine.
My 2007 Accord V6 was losing a bit of coolant. I replaced the tiny hose from the radiator to the overflow tank and that fixed it. There was a trace of coolant residue in that area and that was such a simple thing it was worth a try. If I hadn't been looking for an explanation for the loss of coolant I would never have seen the coolant residue.
Thanks. I'll take a closer look at all the connections.
Quick and dirty way to test for a bad HG is to have someone start the car from dead cold, with your thumb in the radiator filler neck. Once it's started, remove your thumb and if you smell exhaust, it's the HG.
Block tests can be ok to confirm a suspicion but a negative result means little as they're not all that accurate. IOW I think false positives are rare but false negatives abound.
And make darn sure you know the color to start because the change can be gradual and subtle. I reco pics with the same camera, same angle and same lighting before/after for a sanity check -- although it's entirely possible the need for frequent sanity checks is unique to myself
Pressurize cooling system with your tester and allow it to sit pressurized for a while. Using your camera boroscope, preferably an articulating one, you may find drops of coolant entering each cylinder.
I've seen videos of this being done for diagnosing 1.5T honda engines blown head gaskets. Looks really cool...on someone else's 1.5T
  • Haha
Reactions: D60
I would also put some UV dye in the system, run the engine long enough to circulate. Use a black light at night to see any traces of dye, it will make it easier to see if there is leaking in the cylinder. In this case the head has to come off anyway for the intake valve issue so you are just confirming no external leaks.
https://www.amazon.com/Genuine-GM-12378563-Fluorescent-Coolant/dp/B000QIJH2I
Yes in particular there is a coolant system through the intake and throttle body which can leak into the intake and cause white smoke just like a bad head gasket.
Valves should be adjustable from outside. You could loosen the valves on the bad cylinder to make sure they are all slack then leakdown test again to see if there is an internal problem.
Thanks mk378. The intake on this is plastic and it has an inlet and outlet for coolant. I'm sure this is only for below freezing, so I'll bypass the intake and see what happens.
I never thought about UV dye in coolant. Great idea Trav. Thanks !
Update Aug 27: no pressure at the rad on a cold start. I did a combustion fluid test with the engine at running temp and zero change in color. I will try a combustion fluid test with a cold engine and dye in the coolant next. Also, the plastic intake does not have coolant hoses, only the throttle body.
