Who are you using for jetting parts?Can't find my box of timing advance keys.
Plus I know I don't have a 8 degree timing advance key.
So I ordered an 8 degree advance key, the thin head gasket and some main jets.
If i need one or 2 jets ebay sellers can get them to me in about 3 days.Who are you using for jetting parts?
Yeah have an old gx390 that had a dished piston. It needed to be rebuilt and when I rebuilt it I used a cheap Chinese flat top piston. It makes 125psi of cold compression at 4,400ft above sea level. That's supposed to be the top end of compression on a new engine at sea level.I do believe most if not all GX200's come with a dished piston. You can swap in a flat-top pretty easy which should increase power a tad.
I have an older GX160 (old enough it came with a dished piston) That I would use as a snowblower engine in the winter and both a water pump and pressure washer engine in the summer. It always did whatever job I asked of it, however it had very little power in reserve.
I swapped out the dished piston with a flat-top, installed a CL-1 cam, valve springs to keep things in control, and left the timing alone. The difference in power was night and day, plenty of power in reserve, runs perfectly fine. This cam works just fine in the rpm range I use it 3400-4000 rpm.
This GX160 came with a #70 main jet and needed an 85 to be happy afterwords. Lots more power, a GX200 should respond very similar.
Since this engine is used on an air compressor you will be concerned with off-idle response when more air pressure is commanded. I can assure you even with the cam no low rpm response has been sacrificed.
How are you getting 125psi? Is your compression release non existent or disabled?Yeah have an old gx390 that had a dished piston. It needed to be rebuilt and when I rebuilt it I used a cheap Chinese flat top piston. It makes 125psi of cold compression at 4,400ft above sea level. That's supposed to be the top end of compression on a new engine at sea level.
I backed off the exhaust valve valve rocker nut 2 full turns.How are you getting 125psi? Is your compression release non existent or disabled?
Timing advance should put less heat into the exhaust.After seeing this thread, I think we know why Oil pan's mower has a glowing exhaust. Leaned out carb and advanced timing.
So you've got something like .020 or .030 lash?I backed off the exhaust valve valve rocker nut 2 full turns.
More like .080''. That was only to get a compression reading without the compression release activating. When I was finished with the compression check 8 set the valve lash for whatever it's supposed to be, several thousands of an inch, I think it was 7 or 8 thousands.So you've got something like .020 or .030 lash?
What benefit are you looking for?
Gotcha. What was the difference between the dishes and flat top pistons?More like .080''. That was only to get a compression reading without the compression release activating. When I was finished with the compression check 8 set the valve lash for whatever it's supposed to be, several thousands of an inch, I think it was 7 or 8 thousands.
Factory ignition timing on an air cooled engine is around 20 to 22 degrees, which is close to 1980s epa approved smog motor timing where you set the base timing for like 4 degrees and get up to another 20 degrees or so of mechanical advance. In epa approved mode your probably running around 24 degrees of base and mechanic advance at 3600rpm at sea level.Of course you are correct that retarded timing increases exhaust temps, but excessively advanced timing also increases engine temps.
In this case the normal compression test for a new gx390 at sea level with a dished piston should be 125psi max. I'm at 4,400ft above sea level and I'm getting 125psi with the flat top piston and thin gasket. At 4400ft I should be seeing more like 100 to 105psi on a new bone stock gx390 with a dished piston and thick head gasket. So the flat top Piston and thin head gasket has bumped compression at least a full number.Gotcha. What was the difference between the dishes and flat top pistons?
It has the correct jet for 4,400ft above sea level and factory ignition timing, which for 4,400ft would make it slightly retarded.Of course you are correct that retarded timing increases exhaust temps, but excessively advanced timing also increases engine temps.
