I put a Honda gx200 on my air compressor, bone stock from the factory.
It was running so rich my eyes were burning form 50 feet away with ethanol free gas.
I opened up the carb, pulled the main jet and found it had a #75. Got into my jet collection and the next 2 smallest jets I had were a #69 and a #65. So I put the #69 in. While I had the carb off I made the air bleed adjustable with a Dremel, it had that limited 1/4 turn epa approved bs. Just grinding away the blocking tab allowed for full rotation of the screw.
Backed the screw off 4 turns.
I'm going to try the #65 jet just to see what happens. The #69 is still a bit rich, it starts first pull and I can turn the choke off right away and it stays running. The perfect tune I need to ride half choke for 10 to 30 seconds to keep it running.
Next mod, ignition advance. Since the "idle" is about 1,800rpm because it's always under load I'm thinking bump the advance another 6 to 8 degrees.
I forgot to check if this engine has the standard 1mm thic head gasket, if so I'll replace it with an ultra thin head gasket to bump compression.
I'm not going to mess with the exhaust or intake. Ideally I'll simply remove the intake cover for cold air in the summer and leave the cover on in the winter to trim the air fuel mixture.
