Hey Folks,
I have an intermittent wobble/vibration going on and I'd like to add some grease to the axles of my '07 CR-V. Boots are intact, but I'm not sure what grease to use. I've heard that the inner grease may differ from that of the outer joint grease and wanted to consult the pros.
This is an easy & cheap thing to troubleshoot/fix and I'd like to give it a whirl. The car has 207k miles on it, and the axles are all original, boots are intact. It could be the rear axles too, but it feels like the vibration is coming from the front.
Yes, brake drag, warped rotors, out of balance and/or worn tires, alignment, ball joints, tie rods...
I'm trying the grease as it seems to fit the bill for what I'm experiencing.
--Cheers and thank you!
