Originally Posted By: Jim Allen
Don't be absurd.
Of course at a high restriction you can feel it. After 13,000 miles, unless you've collected a lot of dirt from being in a dusty environment, you can't.
A worthwhile quote from "Effect of Intake Air Filter Condition on Vehicle Fuel Economy" at
http://www.fueleconomy.gov/feg/pdfs/Air_Filter_Effects_02_26_2009.pdf :
"According to Patil, Halbe, and Vora, it is common for air filter service indicators to be set between about 5.0 and 7.0 kPa, which corresponds to the setting of the unit taken from the Chevrolet Silverado. The unit tested from the 2006 Dodge Ram is set at a slightly lower level, which is believed to be due to the vehicle being equipped with a diesel engine. While the level of restriction on a closed-loop, feedback, throttled, spark-ignition (SI) engine would not be expected to affect fuel economy (as described above), the additional pumping loss might be expected to affect the fuel economy of the unthrottled diesel engine.
This restriction level is noted as the point of critical pressure drop because at levels greater than the “final pressure drop,” overall engine performance begins to degrade significantly."
Another one for context:
"Figure 3.7 shows the acceleration times for the vehicles with both a clogged and new air filter. The data were analyzed from 20 to 80 mph to ensure that the vehicle was at WOT, removing any driver induced variability.
The WOT protocol requires the vehicle to be accelerated at WOT from idle to 85 mph. The driver reported being able to “feel” the restriction created by the clogged filter and sense the decreased acceleration for both the Camry and Lucerne. The Charger was 0.6 seconds slower in the clogged state, but the driver reported no noticeable decrease in acceleration."
Here is the chart. Note the incremantal drop in acceleration times between a new filter and a
totally clogged one. Tell me again that you can "feel" the difference in a lightly loaded, 13,000 mile filter.
The restriction gauge in my Honda has moved only fractionally in the past 30K (about 45K on the fitler IIRC) and there is no degradation of performance
Your shifting your positions. First,you say,one can't feel a difference when replacing an old AF,then,when called,in this post,you admit one may feel a difference. So which is it? I,others,and the driver in the test,you linked,noticed a difference in engine response when changing out an old AF. The fact that you don't notice a difference is unique to you,not to others.
