Honda 390GXV, 3013H riding mower
Sam_Julier
$100 Site Donor 2026
Staff member
Connecticut
Out: Delo 15W-40
In: Carquest 15W-40
That fits right in with the Volvos :).
Since its a vertical engine probably belt driven hydro transmission?
The larger tank is gas? the smaller hydraulic fluid?
I got it from a farmer in Rowe Mass last summer for free. It had sat in his barn for 4 years. Cleaned the gas tank, carb, new fuel filter and lines, starter motor, starter motor relay, drive belt, ignition switch, spark plug, oil and hydrostatic fluid. It runs perfectly now.
I’m still restoring the 38” cutter deck. I had it cleaned, blasted, zinc coated and powder coated. Now installing new bearings, pulleys, belts, blade shafts, blades, wheels - anything that moves.
It’s a beautiful machine. Almost comically overbuilt.
Yes, belt driven hydro, small tank in the rear is hydro fluid, large one is gas.
