Originally Posted By: Miller88
Originally Posted By: Kuato
Originally Posted By: RiceCake
Its normal. Its just oil seeping out of the lifters. Normally a better filter could shut it up, as a better anti-drainback may keep oil in there, but realistically what you're talking about is totally normal ...
Same in my Grand Cherokee; the lifters bleed down after awhile, and once oil pressure builds and engine temp comes up a bit, it's quiet as it always has been.
Once in a blue moon and 5 ticks isn't anything to worry about IMO.
It comes down to the filter I think. My Cherokee sits for 2 or 3 weeks a time sometimes and the engine is as quiet as can be. The EVAP purge solenoid ... well that makes it sound like it's going to toss a rod at any minute.
I think he mentioned the problem before and after changing filter brands. The ultra he's using now has metal end caps and a silicone (not Nitrile) ADBV, the same setup as the MC filters which are well known for ADB ability. But... the ultra is high efficiency. If the former was high efficiency too, that could be a clue about the oil pump strength. I remember something about honda I4's, oil pumps and oil pressure, maybe somebody with more knowledge can comment.
