Honda 1.5T Oil Choice
Melbourne, Australia
This one seems to be subject to a fair bit of contention.
0w20 or 0/5w30 for the Honda 1.5T motor?
My father has just purchased one of these. I'm personally not too comfortable with a 0w20 in this motor. Keen to hear opinions!
Also, is it worth dumping the factory fill at say 500km?
in hotter climates a 10w30 synthetic is better + Ester based oils handle fuel dilution better than any others
5w30 for sure, at least until you find out whether fuel dilution is an issue here. If fuel dilution is not there, then 0w20 is fine.
I would dump factory fill at 2,000 kilometers.
Do NOT dump that FF. Run that FF oil until the Maint Minder instructs you to.
Well you have two choices. Follow your owners manual or follow the random advice given here.
If the car still has warranty then just follow the manual.
And run the FF till maintenance minder pop up after that you can change at any OCI that you'd like
I'd run 10w30 in Australia, syn 5w30 will also do the job. And really, since it's a commuter vehicle you could get away with 0w-20 as long as you're not short tripping. Again my personal preference is to go on the thick side
I'm thinking of getting one - a US spec Civic Si, although I'm tempted to go for a Type R if my finances work out.
If they recommend 0W-20 I would probably just go with that and change the oil when the OCI says it's at about 10%. Maybe run a used-oil analysis (siphoned) about halfway through just in case if one is worried about fuel dilution. They're specifying for 0W-20 oil even in the hottest climates. I figure as long as the cooling system is doing its job why worry about going with heavier weight oil? If I were worrying about a hotter climate I might just try to bring up the coolant to about 60% water and then change it more often.
Follow one of the only companies who uses 0w-20 oil in a turbo, with the ONLY reason of this persistence is to follow CAFE standards. You have no buffer zone when your motor oil is flooded with fuel. Other manufacturers like Hyundai use 5w30 as their speced oil for turbos with the option to use 5w-40. Their 2.0 liter turbos now have TSB that mandates a full charge to 5w-40 full time speced oil. Hyundai turbos like mine are fighting bad fuel dilution problems too in GDI T motors.
Hmmmm, let's see -- that's a tough one! Start with the Owner's Manual and go from there. Or if one can't be bothered to crack open the book, a peek at the oil filler cap would be a good alternate starting point.
I guess I missed where Hyundai had become the exclusive supplier of engines for Honda. . . The fact that Hyundai mis-designed some of its engines has no bearing (sorry...) on Honda's designs. You don't agree? Then please show us the Honda TSB calling for an immediate change to 5w-40 because of all the failures they're seeing. . . Nope, that's not happening.
Oil gets a lot of fuel in it? Maybe you get effective vis on par with a 0w-16 or a 0w-8 -- not ideal, but both these grades have been successfully used in Japan for years now, and at least as for 0w-16, it's already appearing in mainstream cars here in the US. Additionally, even a light perusal or the used oil analysis section will reveal multiple examples of fuel diluted oil that did not show signs of resulting accelerated wear.
If the OP isn't a troll and comes back and tells us what his manual says, we can take it from there. In any event, I'm willing to bet that Honda has carefully validated the use of whatever oil it is specifying for this vehicle (and all of its others). Yeah, I'm going to go with that over nebulous, vague fears that an oil is just "too thin" every day.
Definitely not a troll, I'm genuinely concerned with the reliability of these motors and wanted to compare:
- BITOG forum views vs other parts of the internet (specifically Civic forums)
My (conflicting) views:
(a) That Honda have designed these engines for 0w20 (bearing clearances/oil flow/oil squirters)
(b) That Honda are using 0w20 oils for the purposes of beating emmissions numbers
That thicker is better (to a degree! I would never consider anything above a 30wt for this engine)
Main purpose is to encourage productive debate. Arguably, everyone on this forum (including myself) is OCD and only wants the best in terms of performance and reliability!
Originally Posted by Jimmy_Russells
I'm going to have to LOL at the assertion that 0w20 spec'd for CAFE for a Honda in Australia.
Its in the manual.
Its in the manual.
But CAFE is a USA thing. (Perhaps Australia has similar?) so were that the reason likely other recommendations would apply outside of USA.
If I owned one of these (And I might soon) I would run what Honda says for how long Honda says at least until such time as oil started rising on the dipstick significantly.
Other manufacturers like Hyundai use 5w30 as their speced oil for turbos with the option to use 5w-40. Their 2.0 liter turbos now have TSB that mandates a full charge to 5w-40 full time speced oil...
Where can we find this TSB mandating Hyundai 2.0T owners use 5W-40? Can you share it, please?
I haven't received it. I haven't read of it on any of the Hyundai Forums, nor is it on any of the TSB lookup sites.
Well, DV0993, there you have it: Go with what's in the owner's manual -- certainly the now time-tested conservative choice -- or opt for a quality 5w30, as have thousands upon thousands of Honda gearheads worldwide.
And DuckRyder, having owned a LOT of new Hondas over the years, I still can't bring myself to own one with the 1.5-liter motor. The two-liter, maybe, but I can't get past the fuel dilution issue that Honda is still trying to solve two years out.
You guys might be on to something here...just maybe the automotive engineers actually spec'd out better lubrication for the engine based tighter tolerances and flow characteristics in order to properly lubricate everything?
Me too
Certainly your prerogative ...
I know several people with these mostly in CRVs and not a one of them has exploded or exhibited any ill effects...
