I recently acquired a Homelite ST-155 string trimmer. I bought it at an estate sale so I don't know the history on this unit. It needed a new primer bulb and head assembly which I just installed. The engine runs/idles well and will start in 3 pulls of the cord/ 1 pull if warm. I've noticed that the throttle response when I pull the trigger is delayed. I press the trigger and then slowly the engine responds and will get up to full speed, but it is not instantaneous. Is this just the nature of the beast, or is there an adjustment I can make? Gas is new and freshly mixed with oil (around 50:1) and the spark plug could be the original champion plug. The air filter was recently cleaned and then lightly oiled. Let me know if there is something else I can check (carb, fuel lines, etc.). The unit runs fine otherwise. Thanks.
-Steve
-Steve
