Homelite Spark Arrestor
TX
I have this old 2 stroke Homelite Leaf Blower, doesn't run well. Cleaned carb and still the same. Took off the spark arrestor and the engine runs without bugging down. So, now I found the culprit, how do I clean this spark arrestor? Thanks
I would use carb cleaner or brake cleaner to dissolve the carbon build up, soak it so you can light it on fire too, and keep it going with a propane torch to burn the carbon out. If that doesn't work, I would drill a hole through if you're not worried about a fire.
Looks like majority says cleaning it with a propane torch. Hmm, I know I got a Benzomatic but needs a propane gas cylinder. Heading to Lowes or Home Depot tomorrow to buy one. Thanks for all the replies. :) :)
