I was quite certain that there was some postings on the "3M" style filters used on furnaces in winter and A/C's in summer. I see listings and when I try to look at them it says the message does not exist.
C'mon gang, donate to BITOG so we can afford more hard drive space and the topics won't have to be blown away!
Perhaps someone can refresh my memory, then. Which plug up too fast? Which are gimmicks? Which really remove smoke, pollen, allergens, dust, etc?
When our furnace was last looked at the techie removed our previous, expensive, comparison-shopped (not by me) filter, and they recommended (and installed) a permanently electrostaticly charged, (increasing-filtration as the air goes through) plastic-fiber-based filter. I believe it is a White-Rogers Part # A0401-16X. The dude said they had used them exclusively for years and no problems at all in thousands of furnaces.
Counter-point? Second thought?
BTW / FWIW the house had no AC when built, they were horrible costly back then. AC's are aftermarket fitted to furnaces and constitute "central air" for homes over 30 years old.
Perhaps digressing from my own topic, the fan motor checks out fine, is permanently lubed, and not ancient, but makes a whine when in constant use or use more than a minute. The sound is high-pitched and annoying, and if anyone has ideas of how to get rid of it before furnace season, it just might save a few headaches
THANKS!
THANKS!
