I can do an quick acid test to check that ROI. How much did you pay? Ie Total price minus the rebates and incentives? You mentioned your system is smaller than what you originally planned. Thanks.My ROI is projected at about 9.5 years
I don't think that'll be the case. There are limits on the value of solar from a grid perspective and once penetration hits a certain point it becomes more of a PITA than a benefit. Australia is already curtailing residential solar, outraging home owners, who of course then don't get paid, which significantly impacts the economics of the system.Twenty years from now all houses will have solar.
Although if energy costs continue to rise, I could see more people installing standalone (not tied to the grid) solar to supplement their needs.I don't think that'll be the case. There are limits on the value of solar from a grid perspective and once penetration hits a certain point it becomes more of a PITA than a benefit. Australia is already curtailing residential solar, outraging home owners, who of course then don't get paid, which significantly impacts the economics of the system.
Yes, consumer non grid-tie uptake of solar will definitely hinge on where grid costs go. Ontario has now plateau'd so we are in good shape. Other jurisdictions are jumping the shark as we speak.Although if energy costs continue to rise, I could see more people installing standalone (not tied to the grid) solar to supplement their needs.
A few examples I've thought of but haven't done anything about yet:
- Have solar panels, even as little as 100 or 200 W, feed a small electric water heater to preheat the water, which would feed the larger primary heater. This would work year-round, although much better in summer of course.
- Have solar panels feed a resistive cable which would charge a thermal mass which would then radiate heat at night. This would only be used in heating season, of course (which is when the solar panels would unfortunately be at their least efficient).
- Build a greenhouse with thermal mass around an air-source heat pump, and add supplementary heat with solar panels (to increase the efficiency of the heat pump). Again, only good in the winter, so not a particularly good match for solar.
These ideas would be fairly cheap to implement, with no need to convert the power to AC or to store it in a battery.
Would any of these ever pay back the input costs? Hard to say. I guess if energy costs continue on their present trajectory these ideas might make sense.
We're at about C$0.10 per kW-h here, so any of this stuff would be more as a hobby at this point.Yes, consumer non grid-tie uptake of solar will definitely hinge on where grid costs go. Ontario has now plateau'd so we are in good shape. Other jurisdictions are jumping the shark as we speak.
Spray foam!I'm doing solar in my new garage build. Zero export mode. I'll probably never make back close to what I spend bur I am ok with that.
Let’s have a beer in 2043. Of course we’ll arrive in our electric cars because we won’t be able to buy an Ice car past 2035.I don't think that'll be the case. There are limits on the value of solar from a grid perspective and once penetration hits a certain point it becomes more of a PITA than a benefit. Australia is already curtailing residential solar, outraging home owners, who of course then don't get paid, which significantly impacts the economics of the system.
You might find this twitter thread interestingq
Let’s have a beer in 2043. Of course we’ll arrive in our electric cars because we won’t be able to buy an Ice car past 2035.I’ll go with “ most homes with south or west exposure will have solar systems in 20 years”, assuming the Woke Governments are still in place.
Yes, thanks to the hydro electric power from the Nelson River development. ( my grandfather worked on it). BC is at C$0.14 on tier #2, and C$0.10 on tier #1.) We blow through the tier #1 pretty quickly.We're at about C$0.10 per kW-h here, so any of this stuff would be more as a hobby at this point.
I can do a quick acid test to check that ROI. How much did you pay? Ie Total price minus the rebates and incentives? You mentioned your system is smaller than what you originally planned. Thanks.
About 26,000. 8000 in rebates. Net 18000. I currently pay $0.29/kWh. The system is projected at 6900 kWh for the year. That number is guaranteed within 10%. ROI projected at just over 9 years.
I caught the solar company in a mistake on system sizing. I found out My utility company approved me for 6kW AC (stumbled up it in a email between me and the solar company in photos of the utility companies Solar sizing calculator) but company only gave me 4.4 kW AC. Trying to get them to do something about it and getting a bit of the run around. Wel see what happens but I feel like I’m wasting my time. Or I just may have to wait until the end of the first full year of production and use my “warranty”. The warranty is enforced by the finance company. Pissed at my self for not catching it before signing paper work.
OK, here is the acid test with the new numbers.Thanks for the update. What are the units on the graph? Are they kWhr per month? If so the system is delivering about 600 kWhr per month averages 600 x 12 = 7200 kWhr per year. Multiplied by 0.18 per kWhr as the present price, it produced 7200 kWhr x 0.18 per kWhr = $1296 worth of power.
The ROI is totally dependant on the expected price of power over the next 25 years. Usually the solar installation company gives you a guesstimate on what that might be. Do you have that projection? Thanks. This is all very interesting and useful to the rest of us.
2x6 , closed cell walls and open cell on ceilingSpray foam!
2x4 or 2x6 construction?
Do you have enough space on the lawn for ground based solar if you cut down some trees?No solar. Too much shade and roof area is too small.
