Remember folks , " A dirty air filter is more efficient " .
To me, you have (2) options, a standard air filter that keeps dust, etc out of the heat exchanger and blower and then you have actual "air cleaner" setups. Those are the ones that use 4" filters that last 3-6 months. Neither are interchangeable.HVAC (furnace) filters were originally meant only to keep dust out of the heat exchanger and blower and later the AC condenser but have evolved into actual air cleaning devices.
I definitely understand your frustrations there. I am in a new subdivision with homes less than 5 years old and have spoken with several neighbors regarding HVAC related issues systems being undersized etc. Neighbors have big mouths until you call them out.. I would like to start a petition in this issue none are willing to go to bat with me.One would think so, until I found out an elderly neighbor's house with less square footage has a 20 x 30 return filter. Same builder, HVAC equipment etc. All of the HVAC ducting and the air handler are in the attic of these homes and there are complaints that the ducts are undersized and rooms farthest from the air handler are hot/cold. We have that problem with 2 bedrooms, the one that faces north is cold in the winter and the one that faces east and gets full morning sun is hot in summer. They may be to size but barely. There was talk of a lawsuit.
if you're selling k&n's lolRemember folks , " A dirty air filter is more efficient " .![]()
love this guy watching his videos especially plumbing has taught me a lot.Steven Lavimoniere
Condenser or evaporator????I clean my coils 3 times a year , it's a good awful job to do it well . But it makes me feel better
I have no condenser , I have geo thermalCondenser or evaporator????
uh that's 16x the restriction of a 4" filter (generically)Use the cheapest filter available, or none, is a work around when the PSC motor in a furnace is dying. Example is when a furnace short cycles as the cfm is too low.
Modern furnaces have ECM motors and often the filter is 4”. Ours is, MERV 13 and now costs $50.
My uncle has a similar setup and to defray costs he stacks 4 1” cheapies
Imagine doing the above especially if allergies
Yes, I have an Aprilaire system on the Carrier air handler in my Florida house. Since Covid, the price of a four-inch 410 replacement Aprilaire filter has gone from $37 to $54. At least they are good for 12 months or more in a clean home without pets and where windows are rarely opened.I just get the cheap fiberglass ones and change every 30 days. There are systems like from AprilAire you can have installed that'll provide more filtration without restricting the blower motor due to the larger filter area. Talk to your local HVAC people for options.
* 4 x 16" x 25"One would think so, until I found out an elderly neighbor's house with less square footage has a 20 x 30 return filter. Same builder, HVAC equipment etc. All of the HVAC ducting and the air handler are in the attic of these homes and there are complaints that the ducts are undersized and rooms farthest from the air handler are hot/cold. We have that problem with 2 bedrooms, the one that faces north is cold in the winter and the one that faces east and gets full morning sun is hot in summer. They may be to size but barely. There was talk of a lawsuit.
@MasterSolenoid what are the dimensions of your filter and how often do you change it? The delta P drop from .3 to .1 WC is significant. Maybe it's time I did the same thing.
Temp drop across the evap coil industry standard is 18° to 24°. 20° is what most techs set blower speed up. Condensate and coil that is saturated with moisture is 100% RH at 40°. When air leaves the coil temp raises and RH drops fast and is lower than the return air. Total agree with your assessment running the blower on the on position dries out the coil and pan when cooling isn't calling.Here is what I have been told....YMMV....
Air flow determines how much water is removed from the air in your home (assuming a properly sized and efficient AC system). If the air flow is too great, too much moisture is drawn off the coils and back into the air resulting in higher humidity.
Not enough air flow and the coils can freeze condensate and block the system. It's a balancing act.
The air flow is adjustable by setting the fan speed and by filter restriction.
Just keep in mind that it is crucial to keep dust and dirt off the coils so good filtration is important.
I'm just the messenger...don't shoot![]()
Ours came with the 413. In 2020 they were four for $122. Now basically $200.Yes, I have an Aprilaire system on the Carrier air handler in my Florida house. Since Covid, the price of a four-inch 410 replacement Aprilaire filter has gone from $37 to $54. At least they are good for 12 months or more in a clean home without pets and where windows are rarely opened.
Our old 1999 system installed by the house seller had jumpers. Normally AC is set higher than heat. But when the system began to fail, the contractor gave me that advice--find the cheapest filter you can, $1 or so, and change it every week. This way, you do not have to replace your system now. He said your PSC motor is like an old man that can no longer blow.Here is what I have been told....YMMV....
When the 1999 system was beginning to fail, I called a contractor due to the advice online (once in a while we have to realize there's plenty of bad and inaccurate advice, even on BITOG! lol). People said our A coil needs cleaning, that's why your AC is not cold. You had a dog--there will be lots of dog hair clogging it up. I'll save you $10k plus--get it cleaned for a few hundred.System must be sized properly to use higher efficiency filters. If not evaporator can ice up. I have custom built home. HVAC systems were sized for pleat filters. 1” Merv 13 in filter grills & 5” Merv 13 filters in filter box at furnace/airhandler. After 25 years evaporators are clean like new.
