608 Type 1 isn’t that hard, which is what I have now along with 609. You can do it online.
While it is true that a lot of systems develop a leak and the refrigerant escapes into the atmosphere, the HVAC installer is SUPPOSED to recover and recycle the refrigerant in any old units. In my area, that means the old refrigerant gets pumped put in a bottle and is taken back to a refrigerant recycler. (BTW, the pump is not inespensive) The nearest recycling station is two hours away, so a trip there and back is a minimum of four hours. So you must spend the gas (and labor) to truck the stuff to their place and then drive back. "Their place" also has some rules that must be followed, as in "no bottle must weigh over 150 lbs". If it does, it will get rejected. They can also claim that your bottle has two separate type of refrigerants in it and will reject it. (My buddy has seen that happen even though there was no way there were two types in it)How does it work then? Do they dispose of the old refrigerant? I highly doubt they would get rid of it given the current prices.
If the normal desire to do something like this ranged from 0-10, this would be a -3 for me.Another good reason to do a lot of this work yourself if you are able.
I don’t know, I kind of enjoy it. I started on cars years ago way before certification was required.If the normal desire to do something like this ranged from 0-10, this would be a -3 for me.
There are reputable HVAC companies out there...they're just few and far between and usually require a bit of effort to find them.
So a company with an EPA certification buys the freon for $16 to $20 a pound, and charging the consumer $95 to $150 a pound is supposed to be acceptable? In whose world is that not considered price gouging or price fixing if most companies are doing that? It's criminal.$95 a pound for 410A is not bad. Everyone around here is $150 per pound. Yes you can buy a jug for 300-400 if you have an epa cert. I just paid $390 for a jug today. But no company is going to sell it to you for what they paid for it.
I don't agree with it but thats how it is. Companies are in business to make money and it takes money to make money. These big hvac companies have a lot of overhead too.So a company with an EPA certification buys the freon for $16 to $20 a pound, and charging the consumer $95 to $150 a pound is supposed to be acceptable? In whose world is that not considered price gouging or price fixing if most companies are doing that? It's criminal.
What are you guys charging for 404A or 134A right now?I am in the business (although I technically am refrigeration, not A/C professionally). I don’t see a recovery charge on your bill (we charge $60 for that)? When you recover refrigerant from a system that someone else has put in, and is leaking (& a blend of different refrigerants as R410A/Puron is), it is risky to recover the refrigerant & reuse it, because-first, you really don’t know what the other company used; second, refrigerant blends leak their component refrigerants at DIFFERENT rates. You really don’t know for sure that what you recovered is actually correct R410A! $95 sounds like a LOT for refrigerant that only costs ~$20/pound wholesale, you got screwed somewhat there. As far as “recycle records”, my recovered refrigerant goes to the supply house, mixed unless it’s R22 or R12 (which they will pay you for), and AFAIK it gets burned by whoever they send it to. Believe it or not, I found a supplier that exchanges tanks FOR FREE, the recovery charge pays for the machine, etc. (I guess, I sure don’t get anything from it). Guessing the supply house has records, the company hasn’t for a decade, probably. And, since the supply house takes it for free, there’s ZERO reason to risk huge fines to release it!
R404A is $36/pound (we sell by the ounce, $2.25/oz), R134A is only $25.60/pound, $1.60/oz. (I think somebody in the office missed the price increase on R134A!)! R404A is far and away the #1 refrigerant I use, R449A is making inroads, though.What are you guys charging for 404A or 134A right now?
In these parts there are a LOT of residential HVAC companies that will incentivize their employees to rip off customers by selling new systems to replace perfectly good existing ones with commissions and even "putting heat" on them if they don't sell enough! I'm not into that, and our suppliers are 4-12 months behind on new equipment anyway...I don't agree with it but thats how it is. Companies are in business to make money and it takes money to make money. These big hvac companies have a lot of overhead too.
1. The equipment the general public can buy on their own is about a 3 on a scale from 1 to 10 as far as quality, real efficiency, operation and longevity.
I don't think Goodman units are that bad.
If anyone thinks Goodman is "good" or 'decent' equipment, you've never had any really good stuff, like a Daikin VRV-S or even Skyair system in a space. Night and day difference in operation, sound, efficiency, quality, etc. Everything.
My Goodman was installed in 1998 and lasted till 2017...no issues..Goodman units, like the ones showing up in every new housing development around here.
It's good enough for most people. Just about nobody buys that high-end stuff you mention, at least around here.
Somebody does. It's not like it's dirt cheap and I just put out a design for a 4-ton Daikin Skyair split system. The condensing unit won't be available until mid-July.
