No real harm, but why dilute your M1?
This seems like a waste of the M1.
How much oil does this car take?
You could either buy enough additional Durablend for one last change or use it in your OPEs.
If you plan a used oil analysis, the sooner you stop adding sodium add pack oils the better.
Two quarts of Durablend will only extend the high sodium levels you'll see with any Valvoline oil, which will in turn at least partially mask any coolant leak, especially if your car has a potassium free coolant installed.
