That is 100% correct countryboy.
My 240sx calls for premium and the ecu is programmed to expect this fuel
It will of course, run on 87 octane, but with a noticeable reduction of power primarily because the ignition timing must be retarded to prevent pinging/detonation.
In a different car, say a base model Honda Civic, the engine is not designed, nor is the ecu programmed, to take advantage of high octane fuel and it won't attempt to compensate for the extra octane. So you are wasting money by using it.
Also, the additives in fuel required to raise octane levels have been known to cause more combustion chamber deposits, (as someone mentioned above)
AND, pound for pound, high octane fuel has less energy than low octane fuel. (measured in BTU's per pound) It's a minor difference but the fact is, in a car not designed for high octane fuel, using high octane can actually make
less power.
(although it is to small of a difference to be usefully measured)
[ November 14, 2003, 12:52 PM: Message edited by: Aaron ]
