High Zinc Content
  • Thread starter Thread starter Al
  • Start date Start date
Al
Elizabethtown, Pa
A friend of mine has the high performance L82 engine in his 1979 'Vette. He says "High Zinc Oil is required. I was wondering if lubes that have a higher dose of Moly/Boron would be better. My guess is they would be.
Thoughts? I am certainly not looking for an argument I flat out have no clue.
The right combination of moderate ZDDP content (~800 ppm) and certain moly-based FMs can work in place of high ZDDP. This is the approach of HPL Bad Ass Racing oil which works well in such applications. Higher ZDDP is a cheaper route and effective.
If the '79 Vette has a stock camshaft with stock rockers and springs, the load at the lifter/lobe interface is likely low enough that a common API synthetic oil, with 700-800 ppm ZDDP, would be sufficient. Not ideal, but sufficient. In such a scenario, a Euro A3/B4 0W-40 or 5W-40 would be a better choice.
I tend to favor peace of mind with the highest quality oil available. Amsoil Z-Rod, HPL Bad Ass, Driven LS/DT, and Red Line HP is where I would look. Valvoline VR1 would be the low end option. Please, do not use BROtella or other API rated HDMOs. Contrary to internet hype, they suck.
Think of it this way. You could have a poodle or cocker spaniel for a guard dog and worry whether or not they'd be good enough, or you could have a doberman and sleep peacefully.
If the engine is stock, the valve spring pressure is mild. There are tons of SB Chevy engines with flat tappet cams running great on 10w30.
Zinc is a consumable; just keep OCIs short.
That era of SBC had cam problems. If it has not gone flat yet it's probably going to be ok. 1979 was not known as a high performance era. The 882 heads are low compression and don't flow all that good.
The valves springs are not that stiff.
Hardly a high performance engine. I would run whatever oil and not worry about it.
