Originally Posted By: Rand
You constantly miss the point GC4lunch
Actually, you have demonstrated in several places in one posting that it is you who have missed the point.
Why dont you list the dry and wet stopping distances of summer tires..
If you had bothered to, like, R-E-A-D the post that you are criticizing, you might have noticed that I cited two sets of tests conducted by Tire Rack using the same vehicle on the same course. One test suite compared four all-season tires; the other compared four non-all-season tires (there is no tire industry category for "summer tires"). Both tests compared the dry and wet stopping distances of the tested tires, The all-season tires had longer stopping distances in the dry; the all-season tires had longer stopping distances in the wet. Most importantly, the difference between the dry stopping distances and the wet stopping distances for every all-season tire was greater than the difference between the dry stopping distances and the wet stopping distances of every non-all-season tire.
oh wait their WET stopping distance is longer too..
As specifically noted in my posting. Oh wait -- you cannot read.
The average of the 4 summer tires took about 22% longer to stop in the wet vs dry.
Actually, as noted in my posting -- I even bold-faced the numbers for you -- the actual difference for the four non-all-season tires were respectively 16.9 percent, 18.3 percent, 19.9 percent, and 17.2 percent. Oh wait -- you cannot read. Apparently you cannot do arithmentic, either, because the average of 16.9%, 18.3%, 19.9%, and 17.2% is not 22%, and not even "about 22%."
you dont compare wet vs dry traction directly
you would have to compare the same tire with and without silica
Leaving aside the obvious question of why I would have to compare the same tire with and without silica, you have set up an impossible condition. When a tire is made, the finished tire either has silica in it (about 99.9% of the tires made for passenger car use today do have silica) or it does not: you cannot simply add or subtract silica from a finished tire. However, the test reports I posted did show the results for the non-all-season Michelin Pilot Super Sport and its direct all-season counterpart in the Michelin line-up, the Pilot Super Sport A/S 3. The reports did show the results for the non-all-season Continental ExtremeContact DW and its direct all-season counterpart in the Continental line-up, the ExtremeContact DWS. The reports did show the results for the non-all-season Bridgestone Potenza S-04 Pole Position and its direct all-season counterpart in the Bridgestone line-up, the Potenza RE970AS Pole Position.
Oh wait -- you can't read.
But this discussion is not about tires with silica vs. tires without silcia, and -- except for some fanciful and, frankly, seemingly dishonest, comments by another poster here, the presence (which may be assumed) or absence (unlikely) of silica in a tire compound is quite beside the point. The discussion is about the inferiority of all-season tires -- as a class -- in wet braking, compared to non-all-season tires (as a general class, and excluding such specialty niches as Extreme Performance tires, racing slicks, M&S off-road tires, etc.).
ALL tires take longer to stop in the wet.
Of course. But the poster whom you are trying to support said the opposite a few posts up, and my post, which you purport to disagree with, contradicted him -- that is, I pointed out that all tires have longer stopping distances on wet pavement than on dry pavement, and I cited actual test numbers in support. Oh wait, you cannot read.
another thing you dont really touch on is.
Simplified:
hydroplaning resistance is mostly a function of TREAD PATTERN.
Traction is mostly a function of the Tread Compound.
You have simplified to the point of falsehood.
Hydroplaning is the phenomenon of the tire riding on a film of water that separates the tread from the pavement.
When the water can be displaced, that is, it can flow, then any tire with tread grooves that are shallower than the depth of water on the pavement will hydroplane, but a tire can hydroplane due to a built up wave (caused by the tire itself) even if the tread groove is deeper than the average depth of water on the roadway, and tread design can mitigate that phenomenon by angled and curved groves that will help steer the flowable water away from the tread area. In fact, the only function of patterns in the tread is to move water. If all roads were dry all the time, then all tires would be slicks with no tread pattern at all.
However, even without standing or flowing water, a tire can hydroplane if it retains a film of water on the tread; that water can still interpose a barrier -- a lubricating barrier -- between the tread of the tire and the surface of the pavement.
All-season tires -- all all-season tires -- are designed in a manner to make water stick to the tread. This is not a matter for argument: it is the definition of an all-season tire; it is what distinguishes an all season tire from a non-all-season tire. They are designed for water to stick to the tread because it is that property that allows the tire to have snow traction; without it, the tire will spin on snow -- which is exactly what non-all-season tires do in snowy conditions.
But because water adheres to the tread of an all-season tire, the tire can and does hydroplane even when there is insufficient water on the pavement to flow. That is the reason why all-season tires as a class have inferior wet braking to non-all-season tires.
Simplified:
