Undriveable is what that would be! It's pretty quick with 350hp!That car would look a lot better with a twin turbo LSX small block in there eh. Maybe just a cool 1,000hp on 91 octane.
Then I would recommend the Bad Ass Racing oil 10w50.![]()
I don’t want to ever experience understeer that that engine would cause in vehicle like that Sportwagon.That car would look a lot better with a twin turbo LSX small block in there eh. Maybe just a cool 1,000hp on 91 octane.
All the possible understeer!I don’t want to ever experience understeer that that engine would cause in vehicle like that Sportwagon.
An aluminum LS only weighs 100ish lbs more...I don’t want to ever experience understeer that that engine would cause in vehicle like that Sportwagon.
I can get oversteer now on cold tires hahaAn aluminum LS only weighs 100ish lbs more...
Converted to RWD and the balance would likely be better. I think oversteer would be the larger threat.
I can use the gas to steer mine pretty well with understeer.Yes i can get my FWD giulietta to under or oversteer by adding or removing throttle on the limit, or even 4 wheel drift but that's a balancing act. Not as much fun as it sounds as no matter what I'm going wider than I'm aiming for. Going to increase the rear grip a bit to have it less neutral. Direction changes are wicked fast now though
Chuck Norris could drive it without understeer.I don’t want to ever experience understeer that that engine would cause in vehicle like that Sportwagon.
Or, you can get BMW.An aluminum LS only weighs 100ish lbs more...
Too bad we only get the worst wagons in the US.Or, you can get BMW.
They are bringing new M5.Too bad we only get the worst wagons in the US.
Now that it's overweight, ugly, and automatic only?They are bringing new M5.
oh well. M2/3/4 are stick.Now that it's overweight, ugly, and automatic only?
...great
We once got pretty good wagons.Too bad we only get the worst wagons in the US.
I remember when first XC70 got out in 90’s. What a skiing machine that was. That Audi 2.5tdi engine was in.
