High mileage section?
Sun and snow
I would be interested in hearing stories about vehicles with high miles and what maintenance and repairs have been done.
-96 Tacoma 3.4l 294k, synthetic 5w30 every 10k. All original including the Clutch and rear brakes.
-98 BMW E36 M3 sedan, 202k. All original. 0w30-10w-40 synthetic, every 9-10k per the OLM.
-12 Honda Fit, 147k, 0w20 8-10k per the OLM.
Today I feel like "high mileage" should be restricted to 250k+....and even that isn't THAT impressive. 300k and more on a gasser starts to interest me a little.
I was talking to a guy yesterday who claims to have owned his '99 Silverado since high school as the original owner. He says 350k on the original 5.3, which is not absurd given the longevity of that power train. I failed to ask about the 4L60
I agree. 300k+ everything starts to get interesting.
  • Love
Reactions: D60
Agreed. I had mentally set the bar at 200k+, but maybe your 250k bar is more appropriate. For example, I am going to go look at a Lexus RX tomorrow (back from the “peak Lexus” days of 2000 - 2010) with 180k on it. Barely a “high mileage” vehicle in my reckoning and experience, since it has been well-maintained per the CarFax and owner.
We have an ES model from that era now with 330k+ on it running like a top. The bar is higher for the key players.
To answer OP’s Q: the keys to a really reliable 330k lexus in great shape were, IME: 1) Mobil 1 + Lubegard in engine, 2) Regular ATF and PS changes also w/Lubegard, 3) annual drain and fill of brake reservoir, and 4) replacing worn components diligently when found - motor mounts, suspension components, hardened/cracked/leaky evap, air, etc. hoses, etc., etc. Catching all this involved nothing more than an intelligent look-around in the engine bay or under when doing oil changes or other work. Only major unscheduled or unexpected component replacements were
-Alternator - 260k,
-PS pump - 240k,
-VVT valves, and
-radiator - 275k.
All of those components TOTAL were about $350 and my labor. And all of those were within the last 90k miles - so it went to 240k with no major unscheduled work other than shocks and rear springs. I had to replace the drive axles around 280k I think, but that’s a wear item and they were cheap and easy to do.
I would be remiss to not also add that the fact it was also all miles from new in Texas and then western WA with no salt or harsh winters helped. I really like driving this car and hope to live to see it hit 1/2 million miles (should be do-able). It’s not that I’m dying ANY time soon (knock on wood), but we just are not putting 15k/20k miles a year on it any more:
(There are a couple hundred pounds of bowling balls in the trunk in this pick so don’t misinterpret the rear suspension angle).
Oh, I also should add it cost me about $15 and about three or four hours of work to restore the interior. It started looking a little worn on the leather about 300k, but this is it now:
There's guy on E46 Fanatics (E46 is the BMW 3 series sold in the US from 1999 to 2006) who has over 700k miles on hi 1999 323i.
  • Like
Reactions: D60
my 99 Cavalier cost **** near nothing to buy and I put 270k over the original 47k mile.
over the years, a starter, a alternator, a water pump, a belt, a brake cylinder and acouple other small things.
oil change every 10,000 miles. that was about it.
my 98 Expedtion was sold with 227xxx miles. I never did much to it repair wise either.
things I can remember were a couple ignition coils, a belt, a vacuum hose and the worst thing was the heater core. sold it still running.
my 93 GMC had 277,000 on it when I got rid of it. honestly never had to repair much on it, but what would be a major disaster for some people only cost me 90 bucks. It developed a cracked piston at about the 170k mile mark, was still running but noisy. it ended up costing me 9 dollars for a piston, 1 ring set and 1 bearing set as well as a head gasket which added up to 90 bucks plus my own labor.. I will admit that when I sold it off, it was tired, especially the transmission
My 2005 Silverado. Right about 250k miles but definitely not all highway, lots of idling with AC or heat on, driving slowly through fields and along trails. Basically all kinds of driving carrying a full payload of land surveying gear. 4L60E is still original as well as the rest of the drivetrain. Front axle seals have been leaking for years. Instrument cluster is half dead. 2 water pumps, 2 wheel bearings, starter, and some very minor stuff other than that.
  • Love
Reactions: D60
I had a 2 year old 1997 F150 2wd 4.6 that I bought with 164,000 miles for 1/3 the cost of the new version of the same truck. Underpowered so lots of WOT especially pulling a car trailer. Sold it when it was 12 years old with 333,000 miles. Best truck I've ever owned. Burned a qt of 5w-30 every 800 miles until I switched to Castrol Syntech 5W-40 which was 1qt every 1100 or so miles. I added at least 150 qts of oil during ownership, but it never caused any issue.
-Alternator bearings at 168,000 miles
-diff rebuilt at 275,000 miles
-ball joints, shocks and tie rods about 290,000
-center bearing and u-joints at 295,000
-alternator at 300,000 along with 1st 8 rib belt
-one O2 sensor
-One tune up
-shunt corroded off original starter
-exhaust twice
Everything else was routine maint. other than having to adjust the read drums up multiple times so it'd stop ok.
  • Like
Reactions: D60
