I think one of the overlooked benefits of High Mileage oils are the extra seal conditioners found in these products.
MaxLife blend for example uses conventional and some synthetic base oils, but the key to these oils are the extra seal conditioners which do work.
Valvoline is claimed to have the best seal conditioners on the market. Over time, they do wear out and become brittle. You also get additional cleaning detergents with these products.
I think for those that don't extend drains past OEM recommendations, and are not seeing extreme temperatures, they are a very good value.
MaxLife 5w30 is also dexos 1 compliant, so it has to be a fairly robust oil.
