skate1968
Brian, if my car wasn't burning so much oil i'd be doing the maintenance dose just like your're doing now.
Quote:
My car burns 5W30 as fast as it burns gasoline.
Quote:
Seriously, how bad is your oil consumption and what type of driving do you do? My '90 Si consumes about one quart per 3000 miles (ARX treated about one year ago, regular oil changes with Chevron Supreme 5w30 or 10w30, but currently Valvoline SynPower 10w30).
Quote:
Merkava, my car has been burning since i got it 7 years ago. But it's gotten worse over time. We've concluded that it's worn rings & possible bad valve stem(s) also. I've already looked at the PCV, gaskets, 'Restorer,' 'smoke away', snake oil, engine swap, rebuild, new car, etc, etc.
Quote:
I recently had a car that was burning oil that bad and it wasn't worn rings, it was gummed up rings....
Then just today (before I read this post) I saw on Pablo's website a method of cleaning up the gum in the engine.
Here's the link http://pws.cablespeed.com/~pablomail/newoilflush.htm
Quote:
Considering the fact that you used restore, the burning may be coming from the valve stem seals..
Quote:
Man, your consumption sounds just like my girlfriends '99 Corolla! After the first 1500 or so miles, it just eats and eats oil. Probably 4-5 quarts of make-up oil after 3000 miles. I typically use Shell 5w30 or Chevron 5w30 if I can get a rebate deal at Checker or Supertech High Mileage 5w30 just to not deal with rebates.
Quote:
Reason for buying Valvoline SynPower for the Civic.... 6 qts at Checker for roughly $21 and $15 rebate. In fact I just got the rebate in the mail Friday. I figure $1 per quart synthetic is a bargain and I can run that for 5-6000 miles. I won't go over 3500 on conventional oil for either of our cars.
