high amp outlets
Near the beach in Delaware
I am looking at a 50 amp outlet that will be surface mounted. Do any brands have a screw pushing on a plate to make the connection rather than just wrapping the wire around a screw. (Trying to find the same kind of connection thats in most circuit breakers these days).
If you want to spend the time you can crimp and solder ring terminals or lugs to the wire ends and put them under the screw. Surface area is the key to carrying heavy current. Sometimes a ring terminal might have to be trimmed a bit to fit. Why crimp AND solder? Crimping, especially stranded wire is a "hit or miss' sometimes. A really good crimper works well with solid wire. Avoid the two dollar Chinese crimpers. I've made several generator to house flex jumpers that way.
E-Heat or an electric car on the way?
Have you looked at said outlets yet? They are much better built than the cheezy 120V/15A ones for normal household duty.
I have used the normal Levitron range & dryer outlets in the past. I was hoping to order something better from Amazon. I ordered a Pass & Seymour outlet today.
