Quote:
Uh....not exactly.
My experience is that even for small vehicles, the specified inflation pressure is all over the lot - maybe not as bad as SUV's, but certainly not very consistent. It all depends on how much load carrying capacity the tires has (how big it is) compared to the weight of the vehicle.
I agree, but what did I say differs from this or conflicts, nothing from what I can tell.
Quote:
AND
Regarding the +5 psi recommendation - even if it results in more than the max as specified on the sidewall, it's still OK.
I would never recommend this to anyone, nor call it ok. It might tolerate psi beyond it' max rating, but the tire isn't designed for it. I won't bother commenting on the horrible ride over-inflating provides, or the accelerated center wear, find me a tire shop or a manufacturer rep that will say go ahead. Liability is the key. No decent tire shop will over-inflate for you, and if something tragic happens, guess where liability lies.
Quote:
Dry traction differences are hardly noticeable and wet traction, especially hydroplaning, are generally improved.
Dry or wet, your threshold limit for traction is reduced if you're running excessive psi. If you've improved resistance to hydroplaning you've raised the outer edges, now you can maintain faster speeds before losing contact, but braking and cornering is compromised. How is this a good thing.
You can't tell me a Toyota Echo, an Avalon, or a Honda Accord or Civic has better handling qualities and traction with excessive psi, let alone it improving in the wet.
