Quote:
"for safe braking, the three-season tire is a better choice"
"Three-season tires do not necessarily have lesser treadlife than all-season tires"
"In heavy snow, both types of tire are effectively useless"
Why then do they call them "three" season tires?
You still are ignoring the COLD-wet issue.
All of the quotations from my previous posts that you have listed above are both true and verifiable (though the first one is out of context).
Non all-season tires are called three-season tires because (as I stated in another post, but you did not quote) they are all but useless in snow. Their tread compounds have been designed to shed moisture, which
aids traction on wet pavement, but which
prevents traction on snow, unlike all-season tires, the tread compounds of which have been designed to retain moisture, which aids traction on snow, but which is a significant detriment to traction on wet pavement.
If I lived in Portland, Oregon, which, as it happens, I do, where we have >100 days a year with wet pavement (and most motorists hardly reduce highways speeds at all in the wet), I would -- and do -- leave my vehicle in the garage and not drive at all on the two or three days a year (some years, it is zero days) that we have snow in the city. I have a set of "chains" (actually made of some sort of fabric) that I keep in the trunk in case I am caught out, away from home, when snow starts. On the rare occasions I have had to use them (over my three-season tires), I have driven at a
greatly reduced speed, and only to a safe place to garage my car.
If I lived in Toronto, as the original poster's mother does, where the streets are plowed clear soon after the snowfall stops, I quite probably would follow the same practice there that I do in Portland.
If I lived in a place where I would anticipate any significant amount (more than ten days per year) of driving on snow, then I would change over annually to real winter tires for the duration of the season when snow might threaten.
Quote:
The all-season tire is therefore a poor compromise, and is neither a good summer tire, nor a good winter tire.
http://www.thetiresguide.com/
(The site quoted above points out that there are
some summer tires that truly are
dry conditions only tires, not three-season tires. I do not disagree with that: the BFGoodrich TA/KD (KD stands for "killer
dry") is an example. But the fact remains: on
wet -- not snowy -- surfaces,
all of the best-braking tires in the world are either three-season tires or summer tires, not all-season tires, because the all-season tires start out from the deep hole of the tread retaining moisture and thus placing a lubricating film of water between the tread and the pavement.)
And as for "cold and wet," the only difference between that and "warm and wet" is whether the tire remains flexible or gets hard at low temperatures. In that regard, a tire with a softer rubber
generally will retain greater flexibility in the cold than a tire with a harder rubber, and so there is (an imprecise, but general) inverse relationship between cold performance and treadwear. For the same reason, almost all true winter tires have soft, low treadlife, tread compounds; and if you want good "cold and wet" braking, you do
not want a high treadlife tire.
