Originally Posted By: SteveSRT8
I am almost certain I met the guy in this vid at the Florida Mile a few years back. They were shaking down a Ford GT with turbos AND a supercharger. Man, what a car!
It used to have a twin turbo/PD supercharger combo, but the s/c itself became was a restriction so it's turbo only now. J. Mihovetz is doing the engines for the car.
Always wondered how the SC could not be a restriction and a power drag as well. If all you want is peak power then a turbo can be hard to beat, but I guess the mechanical blower is a better bet for the street if you want some civility...
I did a big research program about ten years ago on twincharged engines. The roots pump adds to the low end but the turbos get you the big dyno numbers is the general idea. It works okay. Heat soak is a constant problem. I did a mockup for a marine motor and it would heatsoak past a certain point even with an infinite radiator size. Running them on meth helped a lot too - we moved to straight alky motors pretty quickly in that program.
The Roots blower needs to be carefully selected and prepped to work ideally. We spent a lot of time working with BDS experimenting with different rotor seal designs because of the over-pressure.
My customer got bored with it before we could really finalize anything, but I felt like we had a pretty great "outlaw" drag or boat motor in there - I was getting a really remarkably flat torque curve in the 1500 range from about 2400RPM to nearly 7400, IIRC, and it didn't nose over real bad until about 8300.
